Installed the 20amp plug in Passion eBike controller for the Sonders from AliExpress. The unit is a bit bigger and ended up mounting sideways with a plate and velcro. Everything seems to be ok until you take it for a ride. The throttle gets stuck at full on and stays that way until you hit the power button or use the brake. When you turn it back on it seems normal until you hit the throttle again and it goes full bore. The brake safety works but can't figure out why the full throttle gets stuck. Anyone else had this happen?
Getting the new Sondors display tomorrow and see if that makes any difference.
