theemartymac
Does anyone have recommendations for a tiny 48V trickle (+/-1A) charger? Also, any considerations for small chargers? e.g. minimum required output, etc...
I have a long enough commute to work that I'm getting home with maybe 20% or less left in the battery and the power is usually starting to fall off by then, but I don't want to be lugging around the big fan-cooled 3A charger and overcharging the battery with two 100% charge cycles a day. I also don't think draining so low every day will do it any favors in the long run either. I have two bikes with the same battery so I was considering picking up a satiator for the house and charging 80% overnight (alternating batteries which will easily allow for slow charging) and then trickle charging maybe 1.0A or so at work just to get me enough head room to get home comfortably or take the longer scenic route from time to time. I work 10.5 hour shifts, so I can leave it to trickle the entire time at work and still put a good dent in it if not get all the way back to 80% again for the ride home.
The batteries are LG cell 48V 19.2Ah.
