Ezee geared front hub drive with Ezee controller and 36volt battery. All systems operate normally until the the battery voltage drops to 37 volts under load. I hooked up my multimeter to the battery charge port to watch voltage and when you hit 37 volts power is shutoff and the battery reads 5 volts until you turn the "ignition" switch off, or unplug the battery, at which point the battery voltage goes right back to it's non-loaded 38-ish volts. You can then plug the battery in again or turn the ignition on and start using power again until you hit 37 volts.
The Ezee controller does have a way to read out fault codes via it's status LED but the LED turn off with this situation.
I'm wondering if my battery BMS or controller is at fault and if there is a way to verify either without getting a different battery/controller to check against. The battery was recently rebuilt so I'm kinda thinking it's the battery... Any thoughts?
