I run a 18 watt led that is extremely bright. If you don't hook it up wrong it will work with this controller. It can be done... Just don't him it up wrong...eBike controller prices have come down a lot in the last few years. I remember when a Sondors upgrade 20 Amp controller was over $100. The Lectric XP controllers have "waterproof" connectors and these tend to be more pricey than the non waterproof controllers. While something like this includes other ancillary parts, it may be similar to the Lectric XP controller. However, I think after all your efforts, $70 will look reasonable.
Just curious, how did you fry the controller trying to upgrade the headlight? Did you just put a bigger light on the standard headlight wiring or..?
I have four XP bikes...no issues so far. Over one year old 4000km combined. $70 for a controller..two tires cost more than that...It will be very interesting to see what happens after the warranty period is up (or voided by "messing around") for those who still think buying an "inexpensive" bike upfront saves them money long term once the cheaper grade electrical components and motors start to fail. You gotta cut costs somewhere and its becoming increasingly obvious over time where those savings were made. Mine has only 200 very easy PAS 1 or 2 MILES on it, and already the motor is making some bad sounds (and that's after the bike was shipped with a defective battery right out of the box). The bike design is very good. The electrical components are where the upfront savings will be negated over time because unlike a brake pad or a tire...electrical components are expensive to replace once its YOUR money. Seriously..that controller probably cost about $10 to produce (if that).
I'm reminded of that old Soviet proverb -"quantity has a quality all it's own."It will be very interesting to see what happens after the warranty period is up (or voided by "messing around") for those who still think buying an "inexpensive" bike upfront saves them money long term once the cheaper grade electrical components and motors start to fail. You gotta cut costs somewhere and its becoming increasingly obvious over time where those savings were made. Mine has only 200 very easy PAS 1 or 2 MILES on it, and already the motor is making some bad sounds (and that's after the bike was shipped with a defective battery right out of the box). The bike design is very good. The electrical components are where the upfront savings will be negated over time because unlike a brake pad or a tire...electrical components are expensive to replace once its YOUR money. Seriously..that controller probably cost about $10 to produce (if that).
That's good to know. I'll have to add a 1 amp fuse when I upgrade my headlight and add the USB phone holder to that circuit. However, 48 volts @ 1 amp should be more than adequate to power a better LED light/horn and USB charger. The charger should only take about 12 watts leaving 36 watts for the light. A 36 watt LED headlight should be way bright.Two ways. First time I drew 2+ amps thru the headlight circuit charging my phone...poof. Second time I hooked up a 60w headlight, the halo one that seems popular. 60w/50v=1.25amps, well above the 1.0 amp limit.
60 watt headlamp? No wonder it fried...was that LED?...that's an aircraft landing lightTwo ways. First time I drew 2+ amps thru the headlight circuit charging my phone...poof. Second time I hooked up a 60w headlight, the halo one that seems popular. 60w/50v=1.25amps, well above the 1.0 amp limit.
I wired my USB port right into the power supply wires and not jump into any of the controller circuits. It turn on when the key s turned on and it works great,That's good to know. I'll have to add a 1 amp fuse when I upgrade my headlight and add the USB phone holder to that circuit. However, 48 volts @ 1 amp should be more than adequate to power a better LED light/horn and USB charger. The charger should only take about 12 watts leaving 36 watts for the light. A 36 watt LED headlight should be way bright.
You are WRONG. None of lectric controllers have waterproof connectors. Only their LCDs , they claim are waterproof which they arent really. Thats why you see a lot of people put ziplock bags on them lol.eBike controller prices have come down a lot in the last few years. I remember when a Sondors upgrade 20 Amp controller was over $100. The Lectric XP controllers have "waterproof" connectors and these tend to be more pricey than the non waterproof controllers. While something like this includes other ancillary parts, it may be similar to the Lectric XP controller. However, I think after all your efforts, $70 will look reasonable.
You are RIGHT. While the initial connectors on the Lectric controller are indeed SM, and not waterproof, Lectric splices waterproof connectors on to ALL the SM connectors. The splice, at least on my 1.0 is then "sealed" with some type of gel adhesive. The result is that ALL the connectors for PAS, brakes, lights & display are waterproof.You are WRONG. None of lectric controllers have waterproof connectors. Only their LCDs , they claim are waterproof which they arent really. Thats why you see a lot of people put ziplock bags on them lol.
Wonderful. Did it help with PAS issue that people were complaining about - giving same full power at different PAS levels, only with different cut-off speed? I remember a while ago C14 setting was used to adjust the power of PAS, but there were only 2 settings: 1 - less power and 2 - more power, now I see 3?View attachment 117896
I've been up a few steep hills and while not dramatic, it is definately more powerful than the stock controller. As the weather improves, I'll report more or speeds, etc.
One thing I hated about the OEM controller was PAS behavior. It was slow to come on and when it did it was "aggressive" even in the lowest setting. While I have C14 set to 3 (Strongest assist), the KT controller PAS enables quicker and is MUCH smoother. NO abrupt “jerk” after a half turn of the pedal. Another caveat with the KT controller is when using throttle only, speed/power is tied to the PAS setting. That is, in PAS 1, your throttle only speed is limited to about 14 MPH. To achieve maximum speed throttle only, you will need to up the PAS level to 5. There may be a way to override this behavior but I have yet to find it, though I haven’t' looked that hard since I'm OK with it.Wonderful. Did it help with PAS issue that people were complaining about - giving same full power at different PAS levels, only with different cut-off speed? I remember a while ago C14 setting was used to adjust the power of PAS, but there were only 2 settings: 1 - less power and 2 - more power, now I see 3?
Thanks.
If you decide to make throttle work full power on any PAS , try setting P3 to 1.
