Can somebody point me to display codes?
JoyRider
Is there a listing of all of the codes to change tire size, display voltage and other things?
I rode my bike at night a week or so and the backlight was blindingly bright. It would be nice if it compensated for ambient light. Maybe it does with the right tweaks.
Thats actually wrong those are error codes, heres a video explaining all the the settings codes AKA "P settings" and what they do...and how to get to them. You can also unlock your speed to 28mph this way...
Basically to get to them press the up and down arrows at the same time, it will change to the computer settings, you press M to change the setting 'page' and up and down to set the values. The first setting, P1 is the blacklight setting....you can set it to 3 values, I believe I have mine set on 1 which is the lowest.
Since I am bored, here is the settings in pictures; easier to see and diagnose.
It would be a good update for he manual. I added this to my manual.
Code:
Lectric XP Display Settings
P01 1-3 Screen brightness
P02 1 0=km 1=miles
P03 48V battery size
P04 10 sleep timer
P05 1 Number of gears
P06 22 Tire size (Older bikes came 20 and was changed to correct speedo)
P07 1 Magnetic poles. HIGHER IS SLOWER
P08 30 Stock 45+ To unlock PAS speed limit
P09 0 Throttle on=0 Throttle off= 1
P10 2 0=PAS only, 1= throttle only, 2 both working
P11 3 PAS sensitivity
P12 1 PAS strength
P13 12 PAS Sensor type
P14 18 Current limit
P15 40-41.5V Low power limit
P16 0 Hold up to clear Odo to zero
P17 0 auto cruise control.
P18 100% Speed indication ratio
P19 0 Gear
P20 0 Communication protocol
error codes
002-brake error
003-pas sensor error
004-boosting, 6km/h cruise mode
005-timely cruise mode;
006-low battery level
007-motor error
008-throttle error
009-controller error
010-communication receive error
011-communication sending error
012-EMS communication error
013-frontlight error
Bob N
The Lectric Ebike Manual has all the codes and settings for current models, pages 23-26. I attach here too.
  • V1.4_Lectric_XP_Step-Thru_Manual.pdf
