I have no issue with the design, but the quality control in terms of assembly by the Chinese in my case was unacceptable. The battery died after first 13 miles (so it obviously was never tested that all the cells were ok). The derailleur hanger was bent (and not by shipping as the box was perfect...it was bent during assembly) so the gears wouldn't shift. The brakes were not right. One was so tight you couldn't spin the tire and the other so loose, the handle was hitting the handlebars when applied. I took it to a pro bike shop and they weren't surprised because they got another
Lectric XP in before mine with even more issues. So after 3 weeks of getting a new battery and having it back from the bike shop...the bike is NOW ok as it should have been when I got it. Obviously Lectric does NOT check these bikes as I would not expect them to. They are relying on their Chinese partners to do that for them and frankly I give them an F in that department. Also...the bike shop went over the entire bike...the forks and pedals were not torqued correctly. I cannot recommend Lectric to anybody unless they don't mind gambling that their bike will be ok. The bike shop told me that even those buyers who think their bikes are assembled right (correct torques and tolerances on brakes and derailleur)...those buyers will likely have premature wear on the bike much sooner than they should. So folks, I would recommend anybody buying one of these to support your local bike shop and spend another $60 for a professional tune up. Otherwise, you will be spending much more when you start to buy replacement parts.
