pushkar
Here is a peek at our test rig - we pretty much run at 1.5 times the full load, and run the motor at 2300W for 15 minutes.
We are using the kindernay hub - so doing 2 tests in 1 setup
The one thing we will change is that rear sprocket for kindernay needs to be higher than 16T. The chain is just too close .. so pick 17 or even 18 to get better clearance.
First set of motors going out this week. @tomdav We have one with your name on it!
Please note - the controller software and harness will follow early August. However your motor controller is activated, and you will get an email /password on email once the harness and software ships. (I will add that to the FAQs, but wanted to highlight here as well.
