Thanks - The video was informative. I will do necessary change and test the speed tomorrow or on Canada Day.
After changing P08=45, P11=1 & P12=5, I was able to reach a speed of 43 km with full throttle and pedaling. Quite happy with the speed. I also tested cruise control and it did work as well. I am very happy with the bike. Now time to look for more videos and get other add-ons to the bike to make it more efficient for daily commute to work. I am also going to get a GPS tracker for safety and peace of mind.
Its not a hack. And no it doesn't affect the warranty. Its shipped that way as as a Class 2 ebike initially with the option by the owner to change it to Class 3 and to change the decal on the bike...ya right..lolDoes anyone know if you make the PO8 speed hack on the XP whether or not your warranty is still valid?
You have to pedal to reach top speed of 43kms or 28mph. Just throttle won't cut it.
I know how it's designed, we get that. That's why I used the word "unlock". The bike is capable of 28mph and the throttle clearly has a "shut off" at 20mph. I would put money on the fact that a person could disable that shutoff.
Right . I hit 25mph without pedaling and 29mph pedaling hard , top gear 7.
I'm curious about your setup to see if I can higher throttle only speeds as well.
Thanks in advance for your information!
- When did you get your Lectric XP (earlier versions have more firmware settings unlocked)?
- How much do you weigh (I'm 210 lbs so potentially more weight to move)
- What are your P settings?
May the winds be at your back.(still have never seen 30mph .)
