Hi GitaM,I would really appreciate it if you could recommend an eBike that I could use once or twice a week for around Vancouver (hilly).
I am not in great shape so want something reasonable with features that would motivate me to ride. Hoping under $3K Canadian.
thanks in advance.
I fire up ride control on my phone, then pop it into my jacket pocket or rack bag. I don't need to track everything while I ride, but like to see it when I'm done. You can always push the button in the side of the battery to see how much charge is left - easy peasy.Also would recommend the Giant LaFree, but suggest the model E+1 because it has a maintenance free carbon belt drive and internal hub gearing. No chain, no oiling, impervious to dirt, grit, rain, sand, etc. The reduction of required maintenance to the drive train should encourage a "hop on and ride" attitude, and also reduce the worry of riding in places and under conditions that may not be chain-friendly.
You will pay more for the belt drive and internally geared hub, but the payback is more than worth it IMHO. I paid $2,500 (USD) last year for mine.
Tires are wide and designed to ride both paved roads and gravel roads/trails with comfort , ease, and security. Disk brakes for excellent stopping in all kinds of weather and terrain conditions.
400w lithium battery is easy to remove, and can be charged on the bike as well as off. 5 level of assist. Range of distance for charge is anywhere from 74 miles for Eco (Level 1 - 100% assist per pedal stroke) to 39 miles for Turbo (Level 5 - 300% assist per pedal stroke ). I ride in a very hilly area, and find this bike does extremely well with great torque and plenty of power. Extra batteries are available from Giant if one wants to ride long distances (60 miles and up) in hilly locales.
The only drawback to the LaFree models is the lights-only Ride Control One this bike comes with. Impervious to weather which is great, but doesn't give you any digital display. The rider needs a smart phone to get the digital data (plus extra info) that help determine what capacity the battery has at each point in the ride, have GPS tracking, archival storage, and gives totals for the rider to examine after the ride(s).
A very nice, very maintenance free, very comfortable easy entry aluminum ebike for the recreational rider. It does encourage the owner to ride, and makes each ride so much fun, whether riding solo or with others.
More information on Giant's website at giant-bicycles.com
>snip
Size of your body matters a lot. As there are several dealers in Vancouver I suggest you get out and visit some. Shop maintenance for the warrenty can be important if you get a bug. If you put your zip code on the base page, court's finder will show you where they are.
There are 3 seating positions riding a bike. Bent over drop handlebars, forwards mountain bike style, and straight up comfort style. the first is faster with less wind resistance. I have a neck similar to my Mother that popped a disk age 48 and was in pain every minute of the rest of her life. So I sit upright and ride at average 8 mph, not 20 like the lycra bikers. Before I bought a motor a stiff headwind pulled me down to 5 mph one awful day. 5.6 hours on a bike is too long.
Mid drives chew up chains, I ride a geared hub motor over 77 hills in 30 miles. Short hills, those runs from the sea to the park at the top of the sierra in CA & WA can burn up a geared hub motor. 15 minutes max at maximum power on steep long grades. I just changed my chain at 5000 miles and 2 1/2 years.
26" or bigger wheels are more comfortable through potholes, unless you buy a suspension. Suspensions tend to exceed your budget. Fat tires limit the shock of running through a hole, but can be difficult to change the tube out on the road after a flat. I can change my tube in 40 minutes anywhere with 5 lb tools.
Torque sensing makes the assistance start immediately for feeling like you are more powerful than you really are. electra townie go has it with a geared hub motor.
If you're going to grocery shop off the bike, a stretch cargo bike like yubabike, xtracycle, pedego stretch, radwagon, reiss & muller, makes sense. yuba & rad have bosses in the frame to mount a front basket that doesn't swing when you steer. Rad is an internet only bike with no dealer maintenance.
gearless hub drive drags when power is off, and a bit slow out of a traffic light. also heavy, about 10 lb.3/ Mid-drive would be better (lighter, has gears). If going for hub motor (reliable, powerful, Low mtce) I should go for gearless motor and at least 500 watts
QUESTION: Given the above, any other recommendations??
Is it just me? but I don’t see the post by GitaM that you replied to in this thread?My answers in red^^^^^
How many have you test ridden??? That is step number one. Good luck and let us know what you find.
