EffectiveChapter
Hi,
So I finally got the courage to order the mid drive 36v 350w conversion kit and little did I know that torque-sensing motor is not my thing at all. I was looking for zero effort pedaling and what I got was the opposite. I have to crank the assist all the way up to turbo mode (maximum assist) to even feel any proper help . I've changed the power settings to maximum but didn't feel much difference. I do regret buying this motor and not BAFANG, but I've already fitted it on to the bike and can't return it now. I bought it from aliexpress because it was also a bit cheaper than bafang. I should've done more research as all I read is everyone prefers torque-motors, I didn't quite realize why. Another thing I feel like I've failed with is the battery. I ordered it from a local vendor with warranty and not from aliexpress, but I have a feeling all they did was put a sticker on the same battery that is sold in chinese stores. And I overpaid 170 euros for it basically. The battery is 36v 12ah. I assume there is no way to convert torque sensing motor to pedal sensing? I also read that the motor can be programmed to be 500w, but I haven't tried that yet and doubt it would be of help. My only solution was to order a throttle, which now will require to get an insurance.
