This is what the NCM Bike company sent me.
The system provides a discreet to powerful support
(depending on the selected setting) of the driver and also facilitates mastery
of gradients or driving in headwinds. However, it is assumed,
that the system is adequately supported by the user. If the engine
overloaded in this respect, the system automatically switches itself off in order to
technical components from damage.
To avoid this, use the e-bike like a bicycle without electrical
Support for steep longer climbs.
Example for a 7 gear shift:
For steep climbs, select a maximum of support
level 3 and
shift them into a lower gear e.g. 2-3 and support the system.
If tours with several gradients should be made,
we recommend that you switch to ECO mode.
In this way you avoid overloading the system and conserve the battery.
You have 6 support levels 0-6
The following data are approximate guide values and
can therefore vary slightly.
0 = Motor does not support
1 = 7-10 km/h
2 = 10-13 km/h
3 = 13-16 km/h
4 = 16-19 km/h
5 = 19-22 km/h
6 = 22-25 km/h
In stages 1-6 the motor only supports
up to the specified speed.
All speeds beyond that are controlled by own
to support muscle power.
Among other things, you have 3 modes settings
Steps:
1. ECO = Saves battery capacity (higher range) --> low power consumption = high range
2. normal = average battery capacity --> average power consumption = average range
3. power = lower battery capacity --> high power consumption = short range
