eDean
Easy Motion vs Bosch Second Generation Drive Systems
This review compares the second generation Bosch 36 volt mid drive 350 watt to the BH Easy Motion 36 volt rear geared hub 350 watt 2014 drive system. These drives are used across multiple bikes. Bosch is used by many manufactures and BH drive is proprietary to BH. I wrote this on a 10 day cruise with way to many sea days.
This is not really an apples to apples comparison. The Bosch drive has a higher cost than the BH unit. An equivalent bike with the Bosch drive will run around $1000+ or more retail. So what is the relevance? Bikes with a Bosch drive and BH bikes are high quality ebikes with good warranties. Someone looking for a bike like this may very well end up considering bikes with these two excellent drive systems. Does the Bosch warrant the extra money? What are the tradeoffs and real day to day ownership takeaways? I will attempt to answer these questions and a bit more.
BH Pros:
1. Throttle allows for no pedal operation.
2. Less effort required from the rider.
3. Lower cost and complexity.
4. Allows for scooter like operation.
5. Higher speed possible with pedal assist.
6. Frame integrated battery with high stealth.
7. Lazier riding, gear selection is less relevant.
8. Low noise levels.
9. Allows for mutligear front derailleur and therefore wider range of gearing.
10. Higher value.
Bosch Pros:
1. Significantly more responsive intuitive pedal assist at all levels.
2. Eco mode is more comfortable and is not awkward.
3. More demanding of user effort but makes it easier to provide it.
4. Very sophisticated design.
5. Significantly better fuller featured head unit. Nyon may set industry benchmark and will be backward compatible.
6. Easier battery off bike transport due to smaller size and handle.
7. Fixing rear flats is much easier and less frustrating.
8. Overall weight distribution means a more bike like feel and ride.
9. Less chain drop.
Both:
1. Are quality systems.
2. Assist well with climbing.
3. Handle turning at speed with expected results. Weight is low.
4. Have sophisticated assists.
5. Have reasonable warranties.
6. Are safe and will not surprise anyone but the newest of riders.
Motors
Both the BH and Bosch drives utilize torque, cadence, and speed sensing. Information from the sensors is sent to a controller that sends power to the motor. The drives have very different motors. The BH drive is placed on the rear wheel. The Bosch is located in an assembly where the pedals attach to the bike. The location impacts a number of performance issues.
1. Having a hub motor in the rear of the bike puts weight low and back. Low is good but back is not. Optimally the weight should be low and centered. As far as weight goes they are very comparable.
2. The weight of the BH motor rotates with the wheel and there is an associated inertia.
3. In the BH rear hub, changing the rear tire is complicated by the fact there is a motor attached to it. My personal experience matches what I have discussed with other users is that once you get a rear flat on a rear hub motor especially without quick release, your next stop is to the bike shop to buy the most armored tires that will work on your bike. The weight of the motor significantly complicates removing and especially returning the tire to the bike. In some cases, you need tools to remove and restore the wheel.
4. The mid drive uses the bike gears and chain for power. This will be covered in detail later.
5. Having the motor on the rear wheel separates the motor from the crank. In the mid drive, you pedal into a series of gears that powers a chain whether or not power is on. In the rear drive, you pedal a standard front derailleur that attaches to a standard rear derailleur.
6. The rear drive is a much simpler system. It is also less expensive.
The experience of driving both bikes is impacted by the location of the motor. Both motors freewheel meaning that when unpowered, they do not add drag. This is a big advantage of both these engine types. What they don’t do is allow for regenerative braking. For that you typically require a gearless hub motor which don’t make any noise but are less capable at climbing.
When the bike is operated just under human power, they both are very bike like for bikes that weight roughly 50 lbs. The Easy Motion configuration allows for a full complement of gears in the front derailleur. This allows for deeper climbing ratios and for higher speed ratios as well. The deeper climbing ratios make pedaling the bike up hills unpowered an easier task. On the mid drive system, you can feel and hear the reduction gearing - if you look you can see the front gear is very small, and turns twice per pedal revolution. It is something that you get used to, but it is there. On the BH, the inertia of the motor on the rear wheel makes the bike seem even heavier than it is when accelerating. This is apparent when riding the bikes back to back. Like many things, high definition TVs for example, only when you compare side by side can you see what you are missing. If you never do the comparison your screen seems good enough.
Overall, the Bosch system feels more like a regular bike. This is in part due to having the weight very low and centered. Both bikes will corner at speed and follow your intended line though a turn. Any bike with a rear hub and rack mounted battery will struggle at higher speeds around twenty mph. The Bosch system does it more naturally and feels even lighter when pedaled. Unpowered, my opinion is the center drive is slightly better when it comes to the bike experience due to there being no intertia. This given, the BH is surprisingly bike like given the placement of the battery in the down tube and smaller geared motor. The Bosch is more fun to ride as long as you have some level of energy. The difference becomes more important is if you plan of doing any level of technical mountain biking where precision placement, power delivery, and balance matter.
BH Pros:
10. Higher value.
Bosch Pros:
9. Less chain drop.
Both:
Motors
