Racingkyle
What is the difference between the opti bike M7 and R8? is the R8 more powerful?
			Thank you! Pretty ridiculous to add so much money from the M7 to the R8.View attachment 2684 View attachment 2685 Same motor/batteries. The difference I see from the specs here are in the suspension, wheels and the R8 has an internally geared rear hub. Minor (or not) things when compared to the price and builds of both bikes.
I've come to the conclusion that for the same amount of money, stealth bikes offer much more. Also, grace one.15 should be available next year. it's a very impressive bikeYeah it is. I only know one guy who owns an Optibike. He has the Pioneer Allroad and loves it. I've heard mixed reviews from others about the other bikes. I plan on going to the Optibike shop here in Co. in the summer to test some out. Doubtful I'll buy anything as there are numerous similar spec'd e-bikes out there for a fraction of the cost.
I like that bike, just doesn't have enough power for me hahaOh man. You talk'n about the Stealth Bomber?!! That bike is SWEET. Although, I'm super interested in the Specialized Turbo X now.
That's a legitimate reason to like the specialized then!Well. It's specked at 200-250w, but it's nominal out-put is at 750w which is the max for the States and being street legal. I like power too, but I'm worried about the bike doing most of the work for me, whereas I want to 75% of the work, with help on the hills.
I would go with stealth or M1 spitzing.Make sure to let us know what you end up getting and the reasons you why. I'm always interested in how people came to the decisions on the ebike they purchased.
They are pretty good, but you will get way more bike for your money with the M1 Spitzing.Thanks @Shea N Encinitas , what bikes come with the Boshe performance drive? My LBS only sells 3 Haibikes, pictured below. I understand that 350w is what a professional cyclist outputs, and while that is fantastic... I am still hesitant, and leaning towards the a 500w. I would love a Haibike, I want to go off road and explore, but I also need to commute an hour away (14 miles) and I'm just not sure if a full mountain bike will be beneficial for those purposes...?
When I finally get a e-bike. My commute will start at 5 miles one way, but when I transfer colleges, it will be 14 miles one way. Additionally I also weight 275 lbs. So I'm drastically sucking up power from the battery.
How is your Haibike holding up? and what's the commute distance you've gone?View attachment 2739
I'm not sure how the haibike will do for you, not very much power!!Thanks @Shea N Encinitas , what bikes come with the Boshe performance drive? My LBS only sells 3 Haibikes, pictured below. I understand that 350w is what a professional cyclist outputs, and while that is fantastic... I am still hesitant, and leaning towards the a 500w. I would love a Haibike, I want to go off road and explore, but I also need to commute an hour away (14 miles) and I'm just not sure if a full mountain bike will be beneficial for those purposes...?
You can't really compare a 350w geared mid drive to a 500w direct hub drive in simple terms because the mid drive is geared providing more torque, while the direct drive shines once up to speed. Maybe that is why the 60nm spec is so common when talking Bosch. Regarding the M1 Spitzing, $8,500 is quite a bit more than $4,600 (2014) or even $5,200 (2015) haibike FS models. Although both brands have quite a few offerings at various prices (your dealer should order anything you want IMO). As far as your 14 mile round trip, totally doable in tour mode, I've done that much with 800 feet of climbing many, many times. Then when I got a 2nd battery I started doing 30 miles in unlocked turbo mode (swapping batteries with two bars remaining) and repeat that distance almost daily (heading out after this). My Haibike FS RX is holding up great. I did have to tighten a few suspension pivots after 3,000 miles but would keep an eye on any bike getting that much use. Obviously I'm not here to sell bikes, but I sure don't want to see anyone I've befriended end up with a problematic bike. -Best, -SheaI understand that 350w is what a professional cyclist outputs, and while that is fantastic... I am still hesitant, and leaning towards the a 500w.
The M1 is more expensive, but it is built to last like a car. They use an extremely efficient motor which won't burn out over time. They also use batteries that are the newest technology so they last way mor cycles. The motor also cuts off when shifting to protect the gears. also, when in max pedal assist, the motor outputs 550% your torque. that is very substantial.You can't really compare a 350w geared mid drive to a 500w direct hub drive in simple terms because the mid drive is geared providing more torque, while the direct drive shines once up to speed. Maybe that is why the 60nm spec is so common when talking Bosch. Regarding the M1 Spitzing, $8,500 is quite a bit more than $4,600 (2014) or even $5,200 (2015) haibike FS models. Although both brands have quite a few offerings at various prices (your dealer should order anything you want IMO). As far as your 14 mile round trip, totally doable in tour mode, I've done that much with 800 feet of climbing many, many times. Then when I got a 2nd battery I started doing 30 miles in unlocked turbo mode (swapping batteries with two bars remaining) and repeat that distance almost daily (heading out after this). My Haibike FS RX is holding up great. I did have to tighten a few suspension pivots after 3,000 miles but would keep an eye on any bike getting that much use. Obviously I'm not here to sell bikes, but I sure don't want to see anyone I've befriended end up with a problematic bike. -Best, -Shea
