christob
BROKEN SPOKES ; informal survey. If you have broken any spokes on your ebike let me know
1st VEB Cafe - no broken spokes in 850 miles (but then had to swap bike out for a same-model replacement, following a PAS/electronics death.)
2nd VEB Cafe - 5 spokes broke in first 1,300 miles (broken at mile marks: 167, 443, 857, 1115, 1336, over span of 11 weeks.)
VEB identified they'd likely got a batch of bad spokes -- they sent a new, re-laced w/ "good spokes" rear wheel (sent out when spoke #4 broke - but didn't arrive until after spoke #5 broke).
On that new wheel (my bike is a rear hub motor) I've now logged 1,280 miles with no broken spokes.
A recurring chirping squeak recently developed (late Sept.) LBS did a quick check of a few things (not including spokes at that time) but found nothing tell-tale. It remained constant, and a slight shimmy in front wheel at lower speeds, developed. I took it back to LBS this month, and we went over the hub axle and brake calipers, at suggestion of VEB -- both were basically fine. The tech then took it on a quick ride -- the length of the shop -- and said "whoa, something's not right with your rear wheel." And that was when we checked the spokes -- they were almost all of them, substantially loose! (I'd never checked them in my 1,280 miles on that wheel.)
Got them all tightened, and the wheel re-trued the next day -- smooth and quiet sailing once again! So - one more thing to add to my periodic routine maintenance checklist!
