To add the walk assist switch to a 2017
Specialized Turbo Levo (took me about 2 hours as I’m slow):
Note: Soldering required (unless you are smarter than me).
1. Remove the left side crank with an 8mm Allen wrench. These cranks are self extracting. The bolt will lose a few turn then get tight again...Keep loosening it as it is working to extract the crank. You are not braking anything. You do not need to do anything to the right side crank. Leave it alone.
2. Remove the 2 motor covers on the left side around the motor. Note the screws are different lengths so don’t get them mixed up after you remove them.
3. Remove the battery by taking out the upper 6mm Allen bolt toward the top of the frame. It’s just 1 bolt and the battery tilts out of the frame. Lift the battery out of the lower mount that it rest on by the motor.
4. Decide where you want to drill the hole in the frame towards the area the cables come out, up front. I drilled mine on the left side close to where the cables enter the frame but not to close as I didn’t want to create a week spot in the frame with a bunch of holes in one area. Note: the wire for the switch in about 1/4 in diameter. I chose to add a rubber grommet around the whole I drilled so the wire wouldn’t be rubbing on metal so the hole I drilled was 5/16. Also, be away the the connector on the switch is rather large. I couldn’t figure out how to take it apart leaving just the pins to be able to run it easily through a small hole in the frame so I wound up cutting the wire in half, running it into the frame and the soldering the 4 wires back together. If you can live with a big hole in the frame or figure out how to take apart the plug you can avoid cutting and soldering the wire.
5. Now that the wire is run, find on the motor the are where the wires connect. There will be two port with dummy plug covers on them. Remove the dummy plug cover that’s top one ( it sticks out a lot further the the other one) and plug your wire in.
6. Now attach the switch to the handle bar. You will need to remove the left grip, seat post adjuster, and brake lever.
7. Put all your hand controls back on the handle bars.
8. Reinstall your batter using the 6mm bolt you removed.
9. TAKE YOUR BIKE TO YOUR BIKE SHOP AND HAVE THEM REPROGRAM YOUR BIKE.
10. Reinstall the 2 motor covers.
11. Reinstall the left crank arm. Done.
