WarrenInCA
Hitch mounted hanging bike rack. Does anyone know if the ST will go on a hanging bike rack?
			Hi Mike, Just wondered how many miles you're getting on a charge. I did three rides this last week totaling 35 miles and still have two bars. The
I've seen error #7 a couple of times but like you say, turn it off and on and it goes away. It happened once when I was at three bars and going up a long incline but not pedaling hard enough. The bars suddenly without warning, dropped to zero, so I immediately turned it off and used old fashioned leg power to the top of the hill. I then turned it back on and three bars were back. It took me all the way home, about 7 miles with no problem. Lesson, with the battery probably at 50% or less, I wasn't assisting enough and expecting too much out of the motor and battery. I haven't had the problem again. I'm doing at least 35 - 40 miles on one charge with still some juice left. Haven't tested beyond 40 miles yet. I've found riding at a typical road bike speed of about 12 mph gives me the best efficiency. But it's a lot more fun on number 3 riding at about 16-18mph.
I tend to use #4 and 5 only on the hills. My biking buddies are so impressed I just placed an order for four more bikes from Dave sand plan to pick them up in a couple of weeks. All bikes will be equipped with better tires, an adjustable handlebar stem and a 41 tooth front sprocket. Maybe this will be the first E-Glide club for seniors.
Wow, you are ordering so many more!?
...Just came back from a ride myself, had a guy stop me and talk to me about my bike after I passed him on his bike going up a hill! He is very interested and will probably look at getting one. I usually ride on Eco, level 2 or 3. Did a 45 km loop once and only used about one bar.
Cool!I haven't tried eco or normal modes yet, only power mode for all rides. Is there a noticeable difference?
4-bike order for each of my friends who I bike with. They were so impressed with their short test ride on my bike that they each ordered one.
Thanks for the great review. I'm looking for my first ebike, but am limited with my budget ceiling of $2k and a delivery disadvantage of being in Honolulu. Had planned on going with Juiced Bikes CrossCurrent S, but the local ebike shop that was carrying Juiced Bikes has since stopped due to issues with getting replacement parts and poor communication with JB. I've also been following the JB forums, and JB seems to be experiencing some quality control issues that can accompany popular products in high demand. I figured it may be best to look elsewhere while they work out their issues. I also looked at Biktrix and Rad Bikes, but they want $400 to ship their bikes. That left 2 models from Voltbike on my list: Elegant and Yukon 750.Hi, I just wanted to write a little non professional review of the E-Glide ST. This is my first E-bike and my decision was based on price, components compared to comparable priced E-bikes, and the two reviews done by EBR. One on the ST and also one on Dave and the E-Glide outfit in Santa Monica.
I received the bike overnight Fedex and it was pretty simple putting it together as long as you have some allen wrenches and a crescent wrench. I paid an additional 75.00 for the Schwable Marathon Mondial tires and I also received the Maxi Ardent off road tires that where originally on the bike. I wanted a more street orientated tire and I love the highly reflective sidewalls on the Mondials.
Since I received the ST on May 9th I've gone on 4 rides, all of them rides I could not have done on my Giant 15 speed bike due to distance, elevation, and today, heat. I'm 57 years old and I just don't have the endurance I once had. The bike is 52 lbs which is not that heavy for an E-bike and with the electric pedaling assist the additional weight just disappears. I also have a bag I hang on the rack that I keep a igloo cooler full of ice and drinks and don't even think of having to carry the extra weight.
The bike is a joy to ride. I can drive farther now then I could if I was 15 years younger on a standard bike. The cadence assisted power is great but since I never drove a torque assist bike or a mid-drive motor I don't have anything to compare it to. The rear hub drive with the cadence sensor works very well.
Now my three little nitpicks.
(1) The controller speedometer is exaggerated and so then is the odometer. I added my Garmin E-Trex to determine the actual speed. This is something I have run across on both my Suzuki motorcycle and Honda scooter. I don’t know why manufacturers of vehicles do that accept maybe due to liability issues. Today I changed the wheel size on the controller to 26 inch and that brought it closer to the actual speed. Next time I ride I’ll try to reset it to 24 inches and see what happens.
(2) The steering stem is not adjustable. The bike is comfortable right out of the box but being a little older I would like a little more relax position with the handlebars. The ST is designed to handle dirt roads so the riding position is a little more aggressive then a comfort bike. I would like the ability to move the bars a little up and back for my taste. The problem with the control cables are you do not have a lot of extra length to work with. Same as regular bicycles and motorcycles. I think if I could move the bars and inch up and inch back it would work for me. Something you might want to consider on your purchase is what type of riding you will be doing. I also want to point out I purchased the 21 inch frame since I’m 6’ 1” and have a 32 inch inseam.
(3) The gear ratio seems like it should be higher to me. The power assist has 5 levels and I have kept it in normal which there are also eco and power modes. Most of my riding I seem to be in 9th and 10th gear. With the power assist even set on level 1 I don’t seem to use the lower gears. I have to say in level 3 in 10th gear I’m pedaling at 18 mph. Sometime I get to the point where I’m cruising and I wish I had another gear or an overdrive. I have to pedal very fast when I’m going like 24 mph. Yes, depending on the road elevation decline you can go a good clip! Once again it may be a safety thing so you are limited on how fast you can get the bike up to. The lower gears would come in handy if you all of a sudden did not have the electric assist to get you home. I seem to feel I would like to pedal a little more leisurely at 18-20 mph.
So my early impression is I got a great bike for the price and it has opened up a whole new world of riding abilities. I'm just starting out on E-bikes but now I got my foot in the door and can start my learning curve. I was also looking at the Rad City by Rad Power as my 2nd choice and if you check out this EBR site there are a lot of great bikes out there to fit your budget. I did not have to pay any sales tax on the bike being out of state so the bike was 1700.00, tire upgrade 75.00 and overnight shipping 175.00 for a total purchase of 1950.00. I have two E-bike stores in my city and a comparable bike out the door would have been 3000.00.
