raymann112
Looks like shipping date has moved out to July. Don't want to wait that long!
You scared me for a second. I thought it was for all orders, just went to the site and saw it was for another running.
There's so any mixed reports on the GA...I'm not sure what to think.Panasonic NCR18650GA cells according to their website. I'm hoping that I can upgrade to the 21Ah battery when they get them in stock.
When I called up earlier in March they seemed to have a lot of slots for May order (2 months wait). Now in mid April they're 3 months away. Grrr. You snooze, you lose.You scared me for a second. I thought it was for all orders, just went to the site and saw it was for another running.![]()
What sort of issues have come up? They seem to be doing okay on my LED headlamps (almost 2 years now).There's so any mixed reports on the GA...I'm not sure what to think.
LED headlamp and use for high demand controller are very different applications. Some beieve, based on testing they will not have as many service cycles as some better suited cells. Unfortunately we'll need more time to see the results. A number of pack builders who build bike packs not just sell them, completely avoid their use. There were several discussions on Endless Sphere. Not without controvercy. I have a small pack to try but it's just going into limited service in a low demand, 15A controller. Time will tell.When I called up earlier in March they seemed to have a lot of slots for May order (2 months wait). Now in mid April they're 3 months away. Grrr. You snooze, you lose.
There's no regen. And the rear wheel is not a quick release.Are there any close up shots of the wiring to the rear hub? Curious if there threaded disconnects to make it easier to remove the rear wheel to change the tire.
I didn't notice any mentions of regenerative braking. Anybody know if it's available and adjustable to different amounts of regen?
Are there any close up shots of the wiring to the rear hub? Curious if there are threaded disconnects to make it easier to remove the rear wheel to change the tire.
Tora, thanks for the photos! I realized my question wasn't very well constructed. I was asking if there were wire disconnects for the motor which there appear to be based on your photo. On one of my earlier hub motor ebikes (a Polaris model) there was no way to disconnect the motor. Everything was permanently wired in which made changing the rear tire very difficult. My Stromer has disconnects on the wires so changing the rear tire isn't that big of a deal.
Regarding regen, it's a nice to have but it certainly isn't a deciding factor for me.
If you're looking for ideas for further videos, something covering the controller and how boost levels are selected would be nice. Keep up the good work.
Dunbar, What tires are you running? I remember in the past Gatorskins, Armadillos, and RibMo were popular anti puncture tires. I'd probably go with a thorn resistant tube as well.. it'd probably add a pound to the rear wheel though![]()
I chose the satiator originally because I could also do a 12V SLA. Something the 72V can't do. I do not agree that 72V is the coming way. I think there will be some serious problems moving up to that voltage. It's now in the danger range for anyone making a mistake in handling. There's really no earthly good reason for a eBike to be 72V. Not when 48V can drive a bike at speeds above the capacity of most bikes to safely stop. I did buy a 72V to experiment with. I may keep it and pitch all the cheap finless and unreliable luna chargers.I recommend buying the 72V Cycle Satiator over the 48V version. It won't charge as fast (5A max vs. 8A) but it will charge up to 96V systems so it should be more future proof. I have one and think it's well worth the money especially if you're getting one of the bigger (more expensive) batteries. I normally charge my 17.4aH battery to 80% at a slow 1A charge rate using my Cycle Satiator.
And yet the existing 2 wheel EV's are higher power packs than the 72V will serve. I'll use mine for 36, 48, and 52V packs as I'm phasing out the 24V pack and now have a dedicated high end charger for 12V. Having two Satiators is the best backup I can think of. And they pay for themselves. Good chat! Thanks!The way I look at it is the 72V Satiator is more future-proof than the 48V version (which only charges up to 60V.) So if system voltages do continue to increase (like you see on electric scooters) than I have a charger that could easily last 10-15 years. Even if e-bikes stay <60V I'm still covered in both scenarios. It is true that the 72V version isn't ideal for systems <48V. If you want to charge systems <48V the 48V Satiator is a better option. The 48V version also does 8A so it gives you the option to charge faster. It's better for the battery to charge slow if you aren't in a hurry.
My main point is that if you're in the market the 72V is the better buy at this point IMO. If you already own a 48V Satiator I wouldn't recommend upgrading at this point.
