Isn't that Park Tool wrench for a single nipple size, 3.23mm? For the same $ the OP can get a generic spoke mutli-tool, just sayin'Definitely NOT 13G spokes. Without spending an arm and a leg, this Park Tool Four-Sided Spoke Wrench would work.
Thanks. I'll keep them in mind.Check your local velofix dealer for their next availability. Mine had quick appointments (next morning) for minor service. Minimum charge is $99 but they can tune other things and answer any questions while they work on your bike. I had a very good experience and will not hesitate to use Velofix in the future vs. lugging my bike to LBS and taking a back seat to the customers that butter their bread paying a premium for bikes. The nice thing about velofix is you are their bread and butter. My velofix dealer gave me his email and is happy to answer questions at no charge.
Fits the three most popular spoke nipple sizes : .127" (3.23mm) , .130" (3.30mm) , .136" (3.45mm)Isn't that Park Tool wrench for a single nipple size, 3.23mm? For the same $ the OP can get a generic spoke mutli-tool, just sayin'
I think we're talking past each other here. The Park Tool SW-40 linked by @Nova Haibike is spec'd for a single spoke size, 3.23mm. The Park Tool SW 7.2 you linked to does fit the 3 spoke sizes you noted.Fits the three most popular spoke nipple sizes : .127" (3.23mm) , .130" (3.30mm) , .136" (3.45mm)
I just watched the Park Tools video. The process of truing the wheel seems simple enough BUT only if you have the necessary tools. I'm wondering whether the destressing the spokes step is absolutely necessary. If yes, that means that I have to remove the wheel, tire, cassette before I can even start. I also noticed that they didn't mention anything about measuring the spoke tension.As always, Park Tool has a video on this topic!
It focuses on using a truing stand, but as others have noted you can do basic adjustments on the bike frame. Lacking a spoke tension meter getting the spoke tension correct is a bit of an art. I more or less use this technique, https://www.sheldonbrown.com/spoke-pitch.html . There's also an app for that;. Who knew...
I don't need a tension meter to determine which spokes are loose.....it's THAT loose.If you're going to attempt it yourself, get a $40 spoke tension meter like this: https://www.amazon.com/gp/product/B07WSSSVZ6
Then use Park Tool's wheel tension web app: https://www.parktool.com/wta
Do this first to see which spokes are loose and to get a feel for how even the tension is. If you're lucky, getting the wheel true would be tightening the spokes that are already loose. If you need to tighten the spokes that are already tight, bring it to an LBS.
With spoke nipples that can be turned by hand riding will eventually damage the rims. As long as none of the still tight nipples haven't started to pull through the rim material it's probably OK.If I rode the bike with several loose spokes about 5-10 miles, do you guys think that I've damaged the rims beyond repair?
I use a 6" crescent wrench to tighten/loosen spokes. A good one, made by crescent tool, not some ****ese toy.My Park Tool TS-4.2 arrives today. Looking forward to trying it out. Since I've never tried truing a wheel, I will report back on my experience. If I fail, I'll probably return the stand, but I'm hoping for good results.![]()
Additional context with my experience. I was tired from long work day yesterday.Well, I successfully trued both the front and rear wheels. Not perfect, but pretty close. Only took an hour to do. Now I have to wait for my tension meter to measure the relative tension of my spokes. Overall, a good investment in my book.
