Hi all,
i am new here. I own a Swagtron EB7 Plus. The reason I got the bike is because it is one of a few affordable ebikes that fit in the trunk of my car. The height opening of the trunk is 19 inches. So any bike thicker than 18 inches will probably be hard to squeeze in there. The issue I have with the bike is that the 16 inch tires mean that I have to pedal a lot even in top gear (7 gear bike). That limits me to motor assist 1 of 3 when riding on flat bike paths. If I put the bike in level 2 or 3 then I cannot keep by pedaling to move even faster. Pedaling becomes useless in level 2 or 3.
I recently found the Volador And I like it. But I have a few questions:
1. How thick is it really when folded? The website says 15.75 inch. Is that accurate? Can someone confirm this number?
2. How much does it weigh? The website says 36 lbs, but an EBR review says that is not accurate because it excludes the fenders and rack and probably the battery. Can someone confirm the weight of the bike?
3. Are the high motor assist levels useless on a flat surface as they are on my Swagtron? Can a rider pedal efficiently in top gear using the top motor assist level?
Thank you.
Thank you.
