Rides4life
- USA
Local pickup only.
Call or text: 248-890-3340
email: [email protected]
The box is in rough shape.
Model#: S7575TG
RECOMMENDED RIDER HEIGHT:
5'4" - 6'2"
250W hub-drive motor with
pedal assist and throttle control
6-speed twist shifters offer
smooth gear changes
Mechanical disc brakes for
all-weather stopping power
2.125-inch wide tires offer
stability and grip
Up to 45 Miles Per Charge
Up to 20 mph
Recharge in 4 Hours
WARNING: ADULT ASSEMBLY REQUIRED
This product contains small parts. Sharp
edges and points may be present during
assembly. Bicycle riding can be hazardous. Do not ride at night.
ALWAYS WEAR A HELMET.
This bicycle meets or exceeds the
Consumer Product Safety Commission
standards for bicycles.
CORRECT FRAME SIZE
For safe and comfortable riding
there should be a clearance of
at least 1-3 inches between the
crotch of the intended rider and
the top tube of the bicycle frame,while the rider straddles the bicycle
with both feet flat on the ground.Women can use a men's style
bicycle to determine the correct
size women's model.
TOOLS REQUIRED
Phillips head screwdriver
Allen wrenches: 4, 5, 6, 8 mm
Adjustable wrench or
open and box end wrenches:
9, 10, 14, 15 mm
Pliers with cable cutting ability
Bicycle tire pump with gauge
Model#: S7575TG
5'4" - 6'2"
smooth gear changes
stability and grip
Up to 20 mph
Recharge in 4 Hours
CORRECT FRAME SIZE
size women's model.
TOOLS REQUIRED
9, 10, 14, 15 mm
