I've replaced the handlebar on my 2022 Ultimate T10 and now I must replace my shift cable for a longer one. This is my first real work on the bike (and first chance to buy tools). The current cable housing is too short, and is tight - like it's been zip tied somewhere inside the frame. If I remove my battery I see a plastic tray with three screws - all cables appear to be routed underneath this tray.. Even if I remove those screws I still cannot remove the tray - it seems to be further fastened somewhere - it's loose but cannot be removed. Is there a trick to removing it, or is removal a fools errand?
I'd like to use the existing housing as a guide rather than the magnet-on-a-wire tool (which I bought recently just in case), is this the usual approach?
My rear brake hose employs a sheath that (Ibelieve now know) allows replacement without routing, I'm curious why Gazelle didn't use a sheath for the shifter cable as well.
