Hello everyone,
I just completed adding a 750w tongsheng tsdz2 to a steel frame miyata road bike. Having fun with it so far but I need to work out some issues. Maybe people here can help.
My display turned off which also turned off the motor 6 or 7 times. I had to turn it back on each time. Any idea what could be causing this? Is there a setting I need to change? My sensor on the rear wheel seemed to be cutting off motor every time I built speed so I turned sensor to the side to see if it would work without it. Seemed okay, but maybe related to the display constantly turning off? After my ride, I disconnected the sensor and gave a quick test ride and bike appears to ride fine without it connected.
What are people using for their front chainring? I am on the stock ring but I feel like I need a bigger ring, 50 or 52 to get the most out of flat sections.
Any other suggestions, I would appreciate. My first time building an ebike.
