So I got a new bike it's a 72v Emmo Knight Sport. I came with 6 12v 20 AH SLA batteries and they wanted $ 1300 for the upgrade to Lithium 30 AH. So I wanted to build my own battery pack using the K2 26650 3800mAH cells. I am going to be making a pack that will be 24s 8p so it will be 76.8v 30.4 AH
Each cell specs are:
Brand: K2
Model: LFP26650E
Capacity: 3800mah
Nominal Voltage: 3.2
Fully Charged Voltage: 3.65 (recommended), 4.1 (maximum)
Fully Discharged Voltage: 2.5 (recommended), 2.0 (maximum)
Continuous Discharge (A): 12
Pulse 30 Seconds Discharge (A): 28
Charge Current (A): 3.8
So my question is the Continuous Discharge is 12 amp since I'm running 8 in Parallel that would be a Continuous discharge of 96 amps. The BMS is rated for 100 amps. The controller is what is in Question if I would need to replace it or not?
Brand: K2
Model: LFP26650E
Capacity: 3800mah
