Did this ever get solved ?I have issue with a stromer st2s
Sound is stronger when pushing brake and when motor accelerate
Anybody knows what's going on?
I have attach the video to this post
Thank you.
It is hard to say much from this video. Is that rust I see on the cogs ? Have you ever ridded on salty surfaces?I have issue with a stromer st2s
Thank you.
This is concerning, it should completely cut the power when you press the brakes. Again maybe a connection issue. Can you also take a video where you are using the brakes?Actually weird things happen, when i stop bike completely, bike pushing me little forward and backward it self
I had to remove battery case and then removed wire from a frame and cut whole plastic plug wrapping to see all cables and soldering
Thanks for reporting this.Issue found, new motor cable ordered
Green phase cable and blue cable (probably hall sensor) was broken inside motor plug
Yes, please do so, I'm curious.Soldering between pin and cable has burned out, it's impossible to just braked inside
I will post some pictures soon, im waiting for new cable
