victrolux
- USA
The regen you get by pulling the brake lever slightly, is not affected by anything in the recup settings. There is a separate setting for adjusting how intense regen you get when you pull the brake; but that’s a separate setting.WOW! Thank you for that awesome guide!!!
If you don't feel like answering another question, I totally understand, but just wondering if I switch to old school recup in the Omni app, if that means that the half pull of the brake level triggers the recup, similar to the way it works on the early models. As you said, this is VERY helpful, because instead of wearing your brakes down, you can use this with a little strategic riding in order to stop/slow down when you need to.
how’s that for a short answer?!
