Stop Intuvia display from swivelling?
michal
Brooklyn, NY
Is there any way to anchor the Intuvia display? I like it angled closest to me, but every time I go over a bump it slowly swivels back and eventually ends up facing almost completely away from me.
Check the screws, make sure they're tight (I almost lost mine after my first ride). I would suggest putting a small drop of LocTite on each screw. If the mount still swivels after tighten up the bolts, you might need to shim out the clamping area. You can small piece of inner tube or tape wrapped around the clamping area (I have done this in the past for bike computers, brake levers and etc that would't hold on tight enough).
Update —
Stopped by Propel Bikes today and they tighten the display mount + placed a shim between the mount and handlebars. Display is MUCH stabler now and only swivels if you intentionally move it.
