Sticky Regen2 mode when braking?
Blue Bill
Recently my ST1 has started to stay in Regen 2 mode after releasing the rear brake lever about 50% of the time. It'll stay in that mode until I hit the brake again or tap.
Any suggestions on how to diagnose or repair this? Is it something I have to get repaired at the dealer or a DIY fix?
I'm not familiar with that issue. I did have my bike in regen mode, but I did that myself. It kind of sounds like your cutoff switch is sticking, but I'd check with your LBS to double check
Only time I have had this was after the lever took a hit. When my mech worked on my brakes for a leaking caliper in gen he ordered replacement from Stromer and brake company and took what ever got there 1st . It was easier/quicker to get the complete brake assembly (handle to caliper) then to get the one part. Can you reproduce and if you pull and release quickly does it go away?
Mark
I noticed this issue on warm and dry weather and after cleaning and greasing the linchpin on the brake lever it worked absolutely fine.
I can reproduce it fairly easily, I bought some contact cleaner and gave it a liberal shot. I'll let it work in to see if it makes a difference.
