What is your take on carbon bikes?I don't know much about metals either honestly, Mike but I know how to read. I know chromoly would be better, but I also know they over-engineer the aluminum they're using and I'm certain it will work out fine. The frame is not going to be the weak link on these bikes.
For a fast bike, it removes over 25 pounds.My take is that I am not a professional bike racer, so I don't need to know anything about, nor have anything to do with carbon fiber, and neither do the tens of thousands of amateurs who are wasting their money on them.
Sorry, the Stealth Fighter weighs 74 pounds the M1 Spitzing 48 pounds. The weight of motor and battery also increases with frame weight. The M1 does 45mph, a motorcycle. I believe the SF only does 35mph.I dont think so, a good aluminum road bike weighs 25 pounds ... carbon won't get it down to zero!
OK. Let's assume CF saves 5 pounds. The controllers should not differ significantly in weight. Does that mean the motors differ by 22 pounds? If not, how is the weight distributed?You're comparing apples to oranges there, Mike.
http://www.extremetech.com/extreme/129709-audis-50-mpg-e-bike-pops-wheelies-boasts-wifi
The Audi 50MPH+ e-bike weighs 24lbs, so does that mean that every carbon fiber bike weighs 50 lbs less than comparable aluminum and steel bikes (e.g. compared to the Stealth Fighter at 74 lbs)? Of course not. You cannot compare two different bike models like that and assume that the choice of frame material is the prime determinant of their weight difference.
A carbon fiber frame should save you ~5lbs over an aluminum or steel frame. Steel frame bicycles (non-electric) tend to weigh 18-30lbs, aluminum ones 16-27lbs, and carbon fiber ones 14-24lbs. There are a lot of variables that change the weight (brand, bike type, etc), and it's totally unfair to say that CF will always save you 25 lbs. There are so many other variables at play that determine the weight of a bike.
The M1 battery is 18Ah. The SF is 20Ah. I think accounts for 2 pounds. Both batteries are LFP chemistry (lighest possible).
So, the motors are 20 pounds different in weight ? The SF is a 3kW hub motor. The M1 is 980W center-mounted.
The SF is not a tubular frame, but a "box". I believe the difference in frame weight is at least 10 pounds.
The two bikes are designed for 35+ mph speeds. Does anyone know the typical weight for a metal frame designed for high speeds? It seems to be around 70 pounds.Tires, wheels, suspension, battery box, brakes, frame design/layout, handlebar, headset, saddle, chain...
I could go on.
