MinnBobber
Hi,
my rear fender popped the bolt that secures it to the rear seat stays.
I had a small bag on the rear rack, probably well under 10 kg limit but there were some poor roads/ lots of bumps.
Note: when this bolt pops, the fender touches tire and you stop in a hurry
Searching, I see a "fender to frame bridge screw" with 3 Nm torque spec.
I assume this is the part???
Clearance looks tough. Can one deflate the rear tire and gain enough clearance VS having to take off the rear wheel??
Or is there a generic nut/bolt/washer that will substitute?
Actually, I need to look closer as there is a rubber plug on top of that fastener and maybe the bolt is still there but the nut
came off???
What's your experience with this issue? Is factory stock part readily available??
Thanks
came off???
Thanks
