Hi, I need some help with my bike. I recently got a hand me down ST1, but it is not responsive. Battery (gold variety) reads ~5v on my hand-held volt meter. Most likely this is why the computer won't start. I have a Stromer charger (the one without an "on/off" switch, and one light that is either green, orange, or red). When I try to charge the battery, the light is red for about 5-10 sec (presumably sensing voltage), then the light turns green, indicating the battery is charged (or more likely that it is not charging the battery). I have only tried to charge the battery connected directly to the charger. I assume the battery is dead and I will have to buy/build a new one, but is the charger behavior normal? I would guess that it would try to charge, but after many hours a dead battery will remain dead. In my case the charger seems to give up so quickly.
Also, looking at the bike, I can see several unconnected plugs; I am wondering what are these for? One is a 3-pronged plug in the battery compartment. The other is a small 2 prong plug that protrudes through the bottom of the frame below the pedals. See my photos. Should I connect these to something? Can I diagnose problems with these cables?
Any suggestions are helpful.
