SOLD: DAHON MATRIX 26" folding ELECTRIC MTB w/ BMC 600watt V2 motor, Cycle Analyst 2.1, xtras $750
hikingdad
DAHON MATRIX 26" folding ELECTRIC mountain bike with super quality, hill climbing BMC 600watt V2 motor, Cycle Analyst 2.1, upgraded controller, extras. I bought a Bulls full suspension ebike, so it is time to let this go.
Most ebikes are set to 15-20amps of power with a cheap controller. They will not get you up a hill or be very fun on a trail. My bike's electronics are upgraded to give you lots of power....and 26mph.
If the ad is up, it is still available. $750 CASH ONLY, no trades. In Thousand Oaks. Email me your name and phone number and a day and time you want to see it, and I'l get back to you asap. Will update or delete below items if sold.
DAHON MATRIX 2009 med. size 26" folding MTB w/ front suspension fork, Origin 8 Spacebars for comfortable ride. Rear rack with Topeak MTX bag w/panniers. Heavy duty MTB tires. Quick release front wheel. Folding pedals. Cannondale heavy duty kickstand. Folds easily with included hex wrench tool, I hardly ever folded it.
Converted to ebike. you can easily remove the battery box and still pedal with the 9 lb. motor freewheeling. Disc brakes could use new pads.
Note: Thudbuster in pics is not included.
Will consider selling bike only (without rear wheel)
BMC V2 speed 600 watt motor purchased from Ilia Brouk (ebikessf.com) w/ 7 sp. freewheel. 2 torque arms on rear motor axle.
Great geared rear hub motor. link on BMC motor: https://endless-sphere.com/forums/viewtopic.php?f=4&t=22103
Battery and controller are mounted in center triangle for optimum, low center of gravity. Much better than a rear rack battery mount like Prodeco.
CRYSTALLYTE 36-72v analog controller, upgraded to 35 amp , CLYTE full Twist Throttle (like a motorcycle)
Cycle Analyst 2.1 battery aHr meter/speed computer w/ limit switch to conserve battery.
Ping 15ah 36v Battery with BMS set to 40amps continuous- mounted in custom box in triangle. Comes with charger.
The battery had a good, long life but now goes only about 4-6 miles, depending on how much you pedal. Will need a new battery to go far. I can recommend this : http://www.ebikes.ca/b3614lim-dt.html# an excellent, matched battery for $485 shipped.
Other good battery options are available too.....Ping still makes very good batteries and will make a high current BMS.
Original cost:
Bike: $750
BMC Motor and controller, throttle, Cycle Analyst 2.1 package: $900
Spacebars $40
Rack and Topeak bag $125
Cannondale heavy duty kickstand. $40
Ping 15 aHr Battery $450
Sell all for $750FIRM. Buy the brand new battery for $485 and you have a 26 mph, 30-40 mile range, suspension hill climber for under $1250.
Factory specs for bike: Wheel Size : 26"
Weight : 12.9 kg (28.4 lbs)
Folded Size : 35 × 97 × 85 cm (13.7" × 37.8" × 33.2")
Frame : OAX Series, 7005 aluminum, patented LockJaw hinges, replaceable derailleur hanger, integrated head tube
Fork : Suntour NEX, hydraulic damping, lockout
Handlepost :Kinetix Comp, riser, double butted 6061, 31.8 mm
Drivetrain : Front Derailleur Microshift, forged aluminium, for MTB Rear Derailleur SRAM X7, long cage, black Crankset FSA Dynadrive,
Wheels : Front Hub Formula disk, 32H, double sealed Rear Hub Formula disk, 32H, double sealed Spokes 18/8 stainless steel or Sapim Leader, stainless steel (EU) Rims WTB SX24, disc only,
Brakes : Avid BB5, disc
Rider height : M: 167 - 183 cm (5'6" - 6') L: 183 - 193 cm (6' - 6'4")
Max Rider Weight : 105 kg (231 lbs)
