I have been planning to add a 750w Bafang mid drive motor to my Kona Smoke, currently set up as a fixed gear mtb (the rear wheel flips around so that it is also a single speed, allowing freewheel coasting). I was going to add a shifter/derailleur/cassette, but I'm wondering if I really have to. I like the simplicity of the derailleur-less rear (especially in the winter), but I'm wondering if having only one speed will hinder the capability of the 750w motor so much that it's annoying, i.e. getting spun out easily on one end or slow starts that wear the mid-motor drivetrain on the other.
Anyone have a single speed ebike? If so, what gear ratio are you running? Do you wish you had more gears?
I've thought about an IGH (which I think makes a lot of sense for commuters) but then I'd have to get a new wheel, and I'm going for value with this buildout.
