I would like to get an ebike, but I’m feeling overwhelmed with the information and choices. It would be much appreciated if someone can send me in the right direction.
I’m not super athletic. I do have a manual pedal bike,(Trek FX,) that I ride regularly, but I’m not up for doing my full commute on it.
I’m only 5’3” tall – my inseam seems to be normal for my height, but my reach is longer (probably more similar to someone 5’6” – 5’7”ish), so I’d probably like a bike with a low standover height (mid-step?), but a longer distance from seat to handlebars, (maybe an adjustable stem or an upright position???)
My budget is $2,000 +/-
I will commute from home to school to work and back home. In my opinion, my commute has steep hills. I have detailed my commute’s elevation changes below to give you a better idea. The majority of my route is on paved roads. The section from school to work is mostly through a state park and I can either take a paved road or dirt single track. A short portion (0.4mi) of the route from work to home is on the shoulder of a 4-lane, 45mph road(reality = 55mph), but there’s also a poorly maintained crushed stone multi-use path, that I have the option to take instead. The rest of the roads are mostly quiet roads through small towns and windy rural roads (all paved) – I prefer paved roads, but having the option to use stone/dirt paths occasionally is nice too.
I would like a speed pedelec (can go over 20mph) and a throttle would be nice (but not totally necessary.) I can re-charge at both school and work, so battery life is not a huge deal, but of course I’d prefer if I could do the whole day on a single charge. Lights, fenders, rear racks are all things I will need. No 700c wheels – I’ve got clown feet and I’m tired of them interfering when I make tight turns. We do get snow; I plan to keep riding in winter, (except I don’t work from Thanksgiving to Easter.)
Straight up, I don’t know where to start with information on mid-drive vs hub drive, number of teeth, forks, etc. I’m not mechanical or detail-oriented. I’d like an e-bike to be reliable and low maintenance. I want to get on and ride and not worry about the technical aspects.
Please guide me. Thank you!!!!!!!!
As promised, this is what the elevation changes on my commute are numerically:
Part 1: Home to School
0.3mi uphill avg grade 4%, max grade 10%
2.6mi downhill avg grade 4%, max grade 13%
1.2mi mostly flat
0.4mi slight uphill avg grade 3%, max grade 4%
0.6mi downhill avg grade 4%, max grade 8%
1.3mi mostly flat
0.3mi uphill avg grade 6%, max grade 9%
0.2mi downhill avg grade 14%, max grade 17% (yes 17%, this is not a typo.)
0.6mi mostly flat
1.4mi uphill avg grade 4%, max grade 8%
0.5mi mostly flat
0.4mi downhill avg grade 8%, max grade 9%
0.9mi uphill avg grade 4%, max grade 9%
Distance: 10.7mi
Min elevation: 807.7ft
Max elevation: 1514.2ft
Total Gain: 1209ft
Max Climbing Grade: 10%
Part 2: School to Work (I have a maximum of 65 minutes to do this section.)
2.0mi undulating
0.3mi downhill avg grade 7%, max grade 10%
0.5mi uphill avg grade 5%, max grade 10%
0.5mi downhill avg grade 5%, max grade 9%
0.3mi uphill avg grade 8%, max grade 16% (again, this is not a typo.)
0.4mi downhill avg grade 6%, max grade 10%
0.9mi uphill avg grade 10%, max grade 15%(not a typo)
1.5mi downhill avg grade 7%, max grade 13%
0.9mi uphill avg grade 6%, max grade 8%
0.6mi downhill avg grade 7%, max grade 12%
0.2mi uphill avg grade 6%, max grade 6%
0.7mi slight downhill avg grade 3%, max grade 7%
0.4mi slight uphill avg grade 3%, max grade 5%
0.2mi mostly flat
Distance: 9.4mi
Min elevation: 897.1ft
Max elevation: 1488.4ft
Total Gain: 1812ft
Max Climbing Grade: 16%
Part 3: Work to Home
0.2mi mostly flat
0.5mi downhill avg grade 4%, max grade 7%
1.8mi undulating
0.4mi mostly flat
2.8mi undulating
0.5mi downhill avg grade 6%, max grade 9%
0.9mi mostly flat
0.8mi uphill avg grade 7%, max grade 11%
0.7mi mostly flat
0.4mi uphill avg grade 4%, max grade 6%
4.7mi mostly flat
1.2mi uphill avg grade 6%, max grade 10%
Distance: 15.1mi
Min elevation: 771.1ft
Max elevation: 1487.8ft
Total Gain: 1921ft
Max Climbing Grade: 11%
1.2mi mostly flat
1.3mi mostly flat
0.6mi mostly flat
0.5mi mostly flat
Distance: 10.7mi
Total Gain: 1209ft
2.0mi undulating
0.2mi mostly flat
Distance: 9.4mi
Total Gain: 1812ft
0.2mi mostly flat
1.8mi undulating
0.4mi mostly flat
2.8mi undulating
0.9mi mostly flat
0.7mi mostly flat
4.7mi mostly flat
Distance: 15.1mi
Total Gain: 1921ft
