Trail Cruiser
Warning: This may not apply to late model mid drives unless it has cable actuated inline shift sensor or it has a manual power cutoff to execute the shift (such as brake cut-off switch).
This idea originated from a standard (non motorized) bicycle application. I always make sure that there is minimal load while transitioning from one gear to the next. This is done by reducing the pedal effort (ghost pedaling) while executing the shift and then resume the normal pedaling effort once the shift is completed.
That is fine and dandy but what about if you are going up an incline and interrupting your pedaling effort means losing momentum and dropping your speed dramatically? It can still be done, you can continue your high pedaling effort and then time your shifting at exactly the lowest torque point of your pedal rotation. If you look at the illustration below, the lowest torque is when your pedal cranks are at the vertical position
wattmatters.blog/home/2015/01/the-sin-of-crank-velocity.html
As also mentioned on this archived blog:
"Shift when one foot is down and you're at the "floating stage", as I like to call it, when the flex of the bike helps lift that 6:00 foot up. Right when you start to press down with the opposite foot. Just go practice it a couple of times; once you find out how to do it, it's easy. Note: I always do it with the same foot. It wasn't conscious, but it just happened to work out that way."
reddit.com/r/bicycling/comments/1g6ay8/questions_about_shifting_under_load_while/?ref=share&ref_source=embed&utm_content=body&utm_medium=post_embed&utm_name=66e8d427797d434192aa28d6e2d1a3ec&utm_source=embedly&utm_term=1g6ay8
The mid drives that I happened to ride can be configured to have a brake cut-off switch which I use as a manual power cut off when shifting. I like it better than the inline cable shift sensor.
In my particular instance, there are 3 things that I have to execute simultaneously when performing the shift. The timing has be right while the crank is in vertical position, left brake is partially tapped, and right hand pushing the shift lever, all of them at the same time. I performed this over and over until I mastered it and became second nature. If you ride a dirt bike, you will understand the fun part of it.
On hub drives, it's the same (minus the brake cut off).
