Have you tried contacting Rad Power Bike by email to check with their prices for replacement LCDs?  The type Rad uses is the King Meter SW-LCD and I don't know if Rad does any modifications to make this version work with the 2015 Rad?
I have a 2016 Rad and was getting a random"30 maintain" error back in Mar/16.  Rad sent me a new controller, wiring harness, and LCD screen.  I changed all three and the "30 maintain" error got even worst and would display the error and power down the Radrover every single time PAS power was activated when using the pedals.  Swapped out the new LCD screen with the old LCD (since that was the easiest to exchange to trouble-shoot) and the I never got the "30 maintain" error again after 10 months and+ 1200  miles.
I just saying if you have an issue with the replacement LCD and you purchased from overseas or 3rd party can be problematic if you need to trouble-shoot, replace, or return with someone other than Rad.   Depending on the issue you are having, a replacement LCD along with a new controller might be needed (both would be cheaper from Rad compared to converting to something from Luna Cycles).
