I installed a shockstop stem on an ST1 yesterday. It mounts identically as the original stem. The spacing for the 4 screws that hold the face clamp were a different spacing than the original. Simply swapping the stem is a no-brainer. If the light mounts on the handlebar, and the clamp goes either side of the stem, then the stems bar clamp assembly width is a concern. The ShockStop's bar clamp assembly is 1 and 3/4" wide. If the light is integrated into the front plate of the clamp, its likely a no-go. I cant tell from photos how the light mounts on the ST2.
My first impression was the recommended elastomers for my weight for a flat bar were way too stiff. I dropped it to the next level down, and there is still very little flex. I'm going to need to ride it more to see if there is any benefit. Right now, I'd say it doesnt seem to do anything for me, but I've only ridden smooth pavement so far. I can go way down in elastomer choices yet. Lots of selection. I noticed after installing it on the fork tube, there is about 1/4" of clamp above the fork tube. IE the fork doesnt fit flush with the top of the clamp. I put the original back on and its the same. I could have removed a spacer ring, but seeing as how the original stem has the same gap from the factory, I left the shockstop with the same recessed gap. Tried 4 times to wiggle/press/whatever I had to do to eliminate slop in the headset bearings, re-clamping the stem clamp bolts till I got it right. Using the ShockStop in the slightly inclined orientation to get a bit more height/upright position.
