DaveMatthews
Profiteering by an Amazon seller (individual jerk) has NOTHING to do with Canada as a country.There used to be a reason why higher prices here were tolerated gladly: we had higher standards.
Nope, you're wrong again, Dave Mathews. It's quite common and has been, long before Amazon even existed. There exists more reasons why that was so, but nonetheless, we pay more.Profiteering by an Amazon seller (individual jerk) has NOTHING to do with Canada as a country.
Lol! OKNope, you're wrong again, Dave Mathews. It's quite common and has been, long before Amazon even existed. There exists more reasons why that was so, but nonetheless, we pay more.
If its inside my garage and I'm after convenience, I use this one from Milwaukee Tool, but only because I already have a half dozen tools that already use these batteries. If this unit is any indication, the whole dial-a-psi thing is dangerous. I learned if I wanted to set a fat commuter tire to 18 psi I needed to set this one to 13. It actually stops at 16. I have other tires in the 50-65 psi range and its similarly, terrifyingly inaccurate. Gotta have a quality gauge that you use for a reality check!
thanks..that is very portable ..have you used it?I like this one from Bolton Bikes: https://boltonebikes.com/collections/tools/products/portable-electric-bike-pump
Me neither - after it arrives and I do the modification. A question comes to mind, though.You can make one that piggybacks off of your existing battery so less weight. One of these absolutely saved my ass when I ran over a half dozen roofing nails from a nailgun strip. I was tubeless and using FlatOut as the sealant. Without this pump to put some serious volume back into my Snowshoe XLs, I'd have been done for on a cargo bike loaded from a Home Depot run.
It took three refills with a block in between each but after the 3rd everything held. No way could co2 or my arms/Lezyne fat micropump do that. The only catch is you need to put your own plug on the end of it.
Have had to use the thing a half dozen times over the last year. Totally spoiled now and won't ride without one.
A Lightweight Electric Emergency Bike Pump
Got an ebike? Use the big battery you are already lugging around to power a small portable pump.talesontwowheels.com
I’ve seen issues with those ports. A 10 cent item and 10 cent quality. I have a USB port voltage tester. But found I have fewer problems with a 18650 power pack. As always, YMMV.Will the USB charging port on the battery be able to deliver enough power?
I've been steering my purchases where possible to have 18650 capability - for example for headlights I use multiple small flashlights that take single 18650 cells. I have 18650 power banks as well. The things about accessing the bike battery that seem important areI’ve seen issues with those ports. A 10 cent item and 10 cent quality. I have a USB port voltage tester. But found I have fewer problems with a 18650 power pack. As always, YMMV.
It doesn't happen often that I go thru the scenario I described earlier here. 26x4.8 tires then. Another time was 26x4.3 Ednas, and on another bike its been 26x4.0 Supercells. I just can't say enough about having a 20-30ah battery to back me up on the pump.a. large tires that might need to be filled several times might need more battery
b. you save carrying the weight of an additional battery
My air pump arrived. Now to buy the 2-prong plug that fits the battery discharge port. It's really a neat little idea, this 48v pump.You can make one that piggybacks off of your existing battery so less weight. One of these absolutely saved my ass when I ran over a half dozen roofing nails from a nailgun strip. I was tubeless and using FlatOut as the sealant. Without this pump to put some serious volume back into my Snowshoe XLs, I'd have been done for on a cargo bike loaded from a Home Depot run.
