TerryV6
The handlebar can rotated with respect to the front tire. The screws seem to be torqued properly but are not clamping hard enough to prevent rotation. Check it by holding your front wheel between your knees and try to rotate the handlebar while keeping the wheel straight. I had my two bolts torqued correctly and could still move the handlebar.
I saw a link on Rad Bikes addressing this somewhat.
radpowerbikes.zendesk.com
RadMini Spacer Replacement Guide
In the unlikely event the spacer is determined to be damaged or non-functional by Rad Power Bikes, it should be replaced. Watch the video below to learn how to adjust the spacer (or replace, if nee...
![radpowerbikes.zendesk.com](https://theme.zdassets.com/theme_assets/763301/012d8a3aefb0e4996a4d15493ce41338e34a6917.png)
