I just got my Rad city bike, so far a like it. I was reading the documentation and came across this.
It is recommended that users pay close attention and ride within the following limitations to ensure the hub motor does not overheat or become damaged from excessive loading.
Do not climb hills steeper than 15% in grade.
When climbing hills reduce the power output when possible. This can be accomplished by pedaling with the bike while in pedal assist modes 1 or 2.
I am somewhat confused as I got this bike to help on the hills. So I went looking for the motor this bike has, I think its the Sihengyi DGW09C,DGW09S which lists it as a 500 watt motor. So then I started thinking is there a duty cycle on this motor?
anyone have any input as to the reason why you should not use power when climbing and is this the motor?
