fveltri
- Other
Hello everybody, this is my first post here and I imagine it will transpire from the following text... I have an old electric mountain bike, trying to fix problems. I get error 24, the motor does not run and cannot find a solution. The manual of my M5 display does not even envisage error 24, which I was told may be ascribed to cabling problems. There is no apparent damage to the cabling. Sporadically, the motor works for a few minutes with no apparent problem but eventually the problem reoccurs. I disconnected the brake sensors but no change. Suspect the controller itself may be defective. Unfortunately, I never got the manual for the controller and I am not 100% sure about the wiring setting, even if it is not impossible to reconstruct. Lishui no longer produces that model, even if I see pictures on the net of similar controllers, with same label but no indication about the producer. I saw here threads about this controller and wonder if anybody can assist, or suggest a shop where I can find a replacement that will not require complete rewiring. So far I only found a shop in Australia, but it does not ship overseas. To sum up, my request is for advice about fixing error 24, a wiring diagram for the controller, and possible source for replacement. Many thanks
