steve marino
Hi. I have an Ancheer E Bike (photo attached) and had an "interesting" problem with it yesterday. For some time I have been hearing what sounded like loose spokes on the rear, but nothing was loose. Yesterday I took off from a stand still and heard a grinding sound, followed by a large vibration. It was close to home so I ignored it, and after a while the motor just quit. Turning off the battery, I turned everything back on and the motor ran for about 5 seconds and cut off again. The bike is always used in throttle only mode, so it's not the sensors, I think.
At the house I took the rear wheel off and opened the motor. No signs of anything wrong inside, but there was a circular gouge lightly cut into the outside of the hub, and a screw was missing from the disc brake rotor assy. Figuring that the screw must have fallen out and got jammed, which caused the gouge, I buttoned everything back up and tried the bike out. Same problem. It runs for about 5 seconds and stops, and won't go again until I slowly rotate the rear tire and at a certain place it goes, then stops . If I give it throttle once it's going again and turn the throttle off after less than 5 seconds it will run for about 5 cycles of that, then it stops again. The controller looks fine, no smell from being burnt, and everything else looks OK.
Does this sound like the motor is the problem? I can get a whole rear assy w/ motor, rim, tire, etc for $200 so that's not so bad, but I am wondering if it is actually the motor or something else? The motor is brushless by the way.
