Problem with new controller
Dwoody1977
United Kingdom
Hi
im new to the forum but not sure where to post this problem
I’ve had a converted ebike for 2 years and really enjoyed using it .
after bad health I put the bike away for a year and it got damp due to a leak in the garage ..
now to the problem ...after trying to put the bike on realised there was no power ..I tested the battery and it was dead.i put a new battery on and that’s working fine ..but the Nike wouldn’t move ..I bought a new controller and lcd display and fitted these but still no movement of the bike when I twist the throttle ..
‘when I connect the learning wire on the controller the wheel starts to spin as it should ,and when I twist theThrottle the motor stops ..?
‘after I disconnect the learning wire and twist the throttle I get nothing
..please could somebody try and put me in the right direction as to what the problem could be.it would be much appreciated ..
ifthis is posted in the wrong place could you tell me where it needs posting
thank you
It may be the default that the throttle won’t work unless you pedal. You can also try “walk mode”. Usually, you’d hold “up” for a few seconds. One of those, if not both, should work.
It’s good that self learning engages the motor properly. Battery is good and motor are good.
