sethmasia
I bought two kits -- a 250 watt 36v kit for my wife's old steel Miyata frame, and a 1000w 48v kit for my old Bianchi klunker. Installation was straightforward. My wife's bike runs beautifully and she uses it for shopping trips two or three times a week.
On the 48v system I didn't bother to connect the pedal-assist input, nor the power-interrupt brakes.
The 48v kit ran well for a half-mile uphill test. But after I shut it down, it would never again power up. No power-meter LEDs, no response to throttle.
Seven wires involved: Four control leads (black ground, red power, yellow and green), three power leads (blue, yellow, green). What should be the values for voltage and resistance through the combinations?
Other questions: Is there a voltage limiter? Does the system shut down if it senses more than 52v for instance? If so, why did it run on initial start-up?
Perhaps a similar issue has been dealt with elsewhere in this forum, but I can't find it.
The vendor is in Hong Kong with a warehouse in the LA area. Shipping on the original kit took only a couple of days. They have been responsive (they did send a replacement controller, from Hong Kong -- took two weeks) but can't provide any sort of technical support, even in the form of an internal wiring diagram for the motor.
Any helpful ideas? Thanks in advance.
- I measure 53v at the leads into the controller. Good continuity through the on-off switch on the throttle.
- Got a replacement controller under warranty. No help.
- Replaced the throttle with a brand new unit. No change.
