Nirmala
I have fallen for ebikes too. That is why I am hopeful for the success of the ShareRoller: http://igg.me/at/shareroller/x/12713097
It may not create the perfect ebike, and probably won't perform as well as a lot of the bikes discussed on here. But if it even works half way well, it could bring the joys of ebiking to a much wider audience. No professional installation needed or even special skills required to get it to work. A simple design and yet it has integrated lights, regenerative charging, a set of easy to swap batteries to add a second battery for more range or upgrade to a larger pack, a range of control options from pure throttle to pedal assist, 750 watts of power in the US, and a price that is within range especially if you already own a nice bike you want to put it on. The largest version with the biggest battery still only weighs around 8 lbs on the bike, smaller ones are 5-6 pounds and that includes the battery, controller and motor. So it will be easy to create an ebike with a 25-50 mile range that weighs less than 40 pounds total, or even less than 30 pounds if you have a super light road bike. You can lock up your bike and then remove the entire unit to take it inside with you for recharging and safe storage. They are making custom mounts to make it work on folding bikes and even scooters.
The only questions are: will it come to market and will it arrive close to the promised date? And of course, will it work well? The roller thing is possibly the weak point although Court did give Version 1 a 9.5 out of 10 when he reviewed the prototype ( http://electricbikereview.com/shareroller/version-1/ ), and now they are on to Version 3. One advantage of a roller is that it applies the power at the outer edge of the wheel instead of the center. This gives it more torque and allows the motor to work at higher rpm's.
I am rooting for it and even upgraded my perk to the standard size battery instead of the smallest battery, just in case I want to use it on other bikes than my already electrically powered Magnum Ui5 (with which I will be using it on the front wheel as a kind of booster pack for the hills here in Northern Arizona). Right now you can even order an entire package of a cheap Schwinn mountain bike, a scooter, and a small ShareRoller for $799 plus shipping. That is an inexpensive ebike!
Note: they extended the pre-order pricing so it is now good until Dec.2nd. I ordered one also just to support the concept and help it get off the ground. Ideas like this one could potentially bring ebikes to a mass market including potentially a lot of the existing bicycles out there. I am keeping my fingers crossed that it makes it.
