CAGE RATTLER
I got my 1st ebike a couple weeks ago and im loving it except being able to ride in PAS1 at a slower speed.
I've went through all settings I could find in the display to slow it down but its still running at around 11 mph.
And thats with the bike in 7th gear with light pedaling. Dropping down to 6th gear or lower results in not being able to keep up with the speed.
The way it is now, gears 1-5 and PAS levels 2-5 are pretty much useless I guess unless im going up a steep hill. My area is pretty flat.
Ive done some research and have read about CYCLE ANALYST 3.0 display that would allow me to dial in the power settings to where I need them.
I have also seen some other displays that have more adjustability as well.
Is CA or the other displays, controller and/or motor dependant on whether they will work? Are any of them a simple plug and play setup?
I have no problem changing out some components or doing some rewiring if need be but have no idea where to start.
Is there any other options to lower the speed/power at the lower levels?
Any help would be much appreciated
(My Bike: Aostirmotor S07-B , 750 watt Truckrun rear hub motor, SW-U-LCD Display)
