Options for additional charger - xduro 29
Christopher85083
I have found the OEM unit from Motostrano, but $180 is a bit steep for a simple charger.
Are there aftermarket chargers that will work safely with the Bosch battery?
@Christopher85083 Taken from the website Hope this helps!
"I found a cheap charger for my eBike with Bosch System on the Internet. Can I use it?
No. Our charger is specifically matched to the Bosch eBike System and has the right software for optimal charging and maintenance of the Bosch rechargeable battery. If you use any other charger, you will void the warranty and also risk more quickly reducing the service life of your rechargeable battery or causing other damage and malfunctions to occur on your eBike System."
