Jay Kay
- New Zealand
The R&M cranks I received on my SD Mountain Rohloff were 175mm, and they were the same on my 2020 Delite and Susie’s 2020 Homage.
I did some research, and it seemed to me that shorter cranks had few drawbacks on an ebike, and obviously gave the pedals more ground clearance, so I purchased some 155mm Hope cranks to give it a go.
First up, I doubt anyone riding my bike would notice the difference if I didn’t say they were shorter. For me, knowing the numbers, I slightly noticed the shorter platform (distance between the two pedals when horizontal and standing on them with my rare off the saddle) and shorter turning circle, but even so it was more subjective than objective. My cadence number was up, which gave some objective data, and a higher cadence is not necessarily a bad thing. The cadence was never high enough that I felt like my legs were spinning too fast. In fact I only slightly noticed the higher cadence.
I achieved 2 cm great ground clearance for my pedals, and overall 2.3cm for the crank arm. Go have a look at your R&M cranks and you will see quite a bit of extra metal sticking down. The Hope arms are significantly shorter, with a flat bottom.
Verdict - definitely get shorter cranks on standard speed bikes!
Cadence on HS versions would need to be tested but will probably be fine with a derailleur or Rohloff! It might be too high with the Vario due to the narrower gearing ratio.
