Neoprene battery cover for radrover
Ryan71
Hi everyone,
I'm new to the world of e-bikes & have lots to learn. I'm hoping someone can recommend a good cover to protect battery & insulate in cold weather.....any suggestions would be greatly appreciated.
This one should fit but check your battery measurements to be sure.
40049
Hey, thank you for taking the time to respond. It looks like this will fit however it's not neoprene. Do you happen to know how critical it is to have some type of insulation against cold temperatures?
I've been told that cod temps can greatly affect battery range? I plan on commuting year round & it get pretty cold here in pa.....thanks again!
I live in northeastern PA and it does indeed get cold here. I'm not much of a cold weather rider and generally don't venture out when the temp gets below freezing. In my case, the loss doesn't really affect my rides.
Battery performance does indeed drop off in cold weather. Storing & charging your battery indoors is always a good idea. The cover I mentioned isn't neoprene but it does contain a good deal of fiber filler which will provide some insulation. The performance loss you see will depend on the length of your commute and whether or not you can store & charge the battery at work.
There have been quite a few posts here on cold weather battery performance. You might want to check these out:
https://electricbikereview.com/forums/threads/cold-weather-battery-best-practices.30229/#post-224575
Batteries are always happier at room temperature, but you can expect to lose about 20% capacity at 15F. If your battery is oversized for your trip anyway, not a big deal. The critical part is not to charge it when it's below freezing. If you have a long trip, I'd think a cover would slow the cooling but it might reach ambient temp by the end of the trip anyway. Without a heat source, the wind cools things off pretty quickly.
Also from NEPA, Dallas.
