AntHobbyist
Hi, I have been having trouble using my Prodecotech Battery on my 1000w 48v Rear Conversion Kit .
- I opened the Battery
-Cut the Negative and Positive Terminal .
-Connected a T connector to both the controller and the battery .
-Turned on the throttle
- I get the RED Yellow Green Lights to turn on
-I twist throttle and get NOTHING
** i TESTED THE BATTERY With a Analog Multimeter and i get 40V
Also the Kit is Brand New . I hanged controllers that didnt work either .
Any help is appreciated . Will provide Pictures in a Few .
My thought is that i cant used the Battery without the Prodecotech Mount that is Required using Key Ignition . But i thought i bypassed that if
i am Getting Power to throttle being that it lit up .
