DashRiprock
I would like to mount (preferably both but at least one) a Dash/Peak to an 1 3/4" tubular frame which, in turn, would be mounted to a very well suspended frame designed for off-road traveling. The bikes will be covered properly and 'I'm guessing' the wheels supported by some other means if not by the mount (preferred).
Are there any companies out there who fashion themselves as the 'gold standard' in making heavy duty mounts? I look at an ebike as something requiring a bit 'extra' in terms of mounting (weight, wire connections, etc.).
Thanks!
P.S. I can fabricate a tube adaptor yet would obviously like to keep the bike as close as possible to the frame. I also realize that a singular round surface is not ideal for doing this and may have to come up with a bracket between the frame tubes.
Thanks!
